usb controller driver
sa3so3a
hi..i formated my vaio pcg-k115s and windows xp couldn't define the usb controller,so if u please i want to know what to do or where to find the driver....thx
kee-lo_
Doesn't it ask for the Windows CD?
TygerTyger
Don't do a straightforward format of the hard drive, it makes one or two things a bit screwy sometimes. Use the recovery disk that came with the computer, it does essentially the same thing as a format, only less convenient.
