VA10 laptop display issues
Spert51
VA10 laptopVGN-NS20MS struggling with screen display particularly on visited site like FB
10 REPLIES 10
Hi Spert51 and welcome.
Can you give us more information please?
What do you mean by 'struggling with screen display'?
:thinking:
Spert51
Hi
Thanks 4 answering.
Example: go on FB game and get either a quarter or 2/3rds of the actual game screen and cannot play...first noticed it when my screensaver was stretched horizontally.Have tried messing around with display features but no joy:smileyconfused:
Spert51
Can n e 1 help me here please?
Desperate! :slight_frown:
Spert51
Hi
No cannot remember doing anything specific and no it has never happened before
rich912
Hi Spert51,
Have you checked that your screen resolution is set to 1280 x 800?
To check this right click a blank area of the desktop and select ‘Personalise’ and then click ‘Display Settings’.
Rich
Go n-éirí an bóthar leat
Spert51
Thanks Rich   yes it is set at 1280 x 800
rich912
Hi Spert51,
In that case I can only suggest that you try a System Restore back to a date when the display was working normally.
Also, have you tried a different browser? However as you say that your screen saver is not as expected this is possibly irrelevant.
Rich
Spert51
Thanks Rich
I have done system restore and no luck!
rich912
Hi Spert51,
I take it that you have tried a different browser?
As a last resort you could try a system recovery to factory settings using your recovery disks or the HDD recovery utility (tap F10 at boot when you see the Vaio logo). Be aware that you will lose all personal data and third party software, so backup your data and accept that you will need to reinstall third party software.
Rich
