Vaio 20GB vs 40GB ?!
emqvaio
Besides weight, dimension, disk size and price, is there any other differences between 20GB and 40GB ?!
Does both have the same battery playback time ?
10 REPLIES 10
Vas
Yes they both have 20Hours Battery hours.
Vas
emqvaio
And do you know if the hard-disks have the same caractheristics (rpm, seek time, data buffer) ?
Sh1nt4
uhm rpm, buffer and so on should be the same, the only different thing is the capacity i think :wink:
nemo66
The 40 Gig is a little bit faster than the 20 because it has more heads (2 more).
emqvaio
And do you think that it could use more battery for that effect ?
Thanks for any info.
I have the 20GB and I really dont need the 40GB, but I can still exchange it if the difference between units is advisable for other technical reasons.
Thanks again.
diverse
The 40gb unit does not fit PDAIR's very nice leather case!
ivan-d
i think the battery in the 40gb is a bit stronger so that the battery life is left the same...
nemo66
Yes, u are right! (it is stronger)
emqvaio
So in your opinion if one does not need the extra space of the 40GB, there is no other (technical) reason to exchange my 20GB for the 40GB, right ?
Thanks for any help.
