Vaio AR61ZU - BSOD and Memory Dump
login365
I purchased a Sony AR61ZU a couple of weeks back and after a few days it did a BSOD and Memory Dump on me then re-booted, which I thought nothing of. A couple of days later it did it again, so I assumed it must be a piece of software that I installed, so performed a factory reset from the recovery partition.
A day or so later, the laptop did it again and I did yet another factory reset. The laptop is still doing it at what seems to be random times. I have attached the dump files to this post, hoping someone can point out what the problem is - I hope someone can help.
Sony AR61ZU
Centrino Duo 2.4GHz
2x 250GB
4GB RAM
Thanks in advance!
Mike
0 REPLIES 0
