Vaio C1z/b with a blue vertical bar on the midle of the lcd screen ???
JMVF
Does it ever happen to anyone? what is the solucion? it has about 1 " width...thanks
Hi JMVF and welcome to Club Vaio.
Are you still using XP?
Does this happen with all applications?
As far as I can see, there is not an updated video driver available for your C1Z.
I think I would have a word with SONY PORTUGAL as a repair may be needed.
They will ask you to restore your Vaio using the Recovery Wizard before they take it for repair as this often resolves many problems. You will need to back up all your data.
:slight_frown:
kee-lo_
Sounds like a loose LCD cable to me, best have that seen to by Sony PT.
