Vaio Care error, i uninstalled how do i get it back?
GS1981
Hi my wife just bought me a Sony Vaio E series SVE1512M1EW.CEK from PCworld (Windows 8 64-bit)
this is the product...
http://www.pcworld.co.uk/gbuk/sony-vaio-e-series-sve1512m1ew-cek-laptop-white-17056565-pdt.html#long...
Every time i restart i get this error....
'Windows Script host
can not find script file "C:\Windows\Temp\VAIO Care Rescue Tool.vbs". "
This was irratating me so i disabled Vaio Care from windows start up, restarted and it did it again, i then uninstalled Sony Vaio Care.....not knowing what it was....
So now i still have this annoying error and i now have no Sony Vaio Care program which i have just realised is used to back up/restore your computer :(
So my questions are...
How can i stop this error happening at start up...
And how can i get Vaio Care for Windows 8 back so i can restore my laptop if i need to?
14 REPLIES 14
rich912
Thanks for the info MrDerp. This has been passed to Support under the escalation.
Rich
Go n-éirí an bóthar leat
rich912
As GS1981 has not responded to emails from Support this question has been marked as 'Assumed Answered'.
Rich
Neil42
Hi Rich
I had the same problem and restored to factory settings.
To recreate the file however, just create a text file called
and enter the lines
' Copyright 2011, 2012 Sony Corporation
Set ws = CreateObject("Wscript.Shell")
ws.run "cmd /c C:\Windows\Temp\deletetempfolder.bat",vbhide
Exit and then copy the file to C:\Windows\Temp
Hope this helps
Neil
dacoomb44
Hi
Do you know iif Sony support ever offered any update on this?  I have a similar message (.Net  Framework but there was no endpoint listening at blah blah blah).  I managed to get it to stop for a while by disabling everything but it's started again even with everything disabled. I thought I had a virus so cleared all my temp files which I think may have brought it back.
It's annoying as it really slows down the boot up time of my computer - by about 10 minutes.
The irony of it being Vaio care that's broke my machine isn't lost on me!
bch0094
how can  i solve it ?? it really dumbed me ...... pls help me ... pls
