hi there
you know when you take the graphics card out and your computer then resorts to using the default graphics,, what is that in vaio coz when i installed my parhelia,,,, it scans for devices that are compatible with drivers you are installing (cd software)
and i get the matrox g550 appear at the bottom saying not compatible ....
so for some reason it thinks i have that in my pc which to my knowledge it isnt
pretty strange aaaaaaaa
reagrds ben
