VAIO doesnt recognise the USB stick, drivers needed?
Felena80
Please help. My Sony VAIO (modelVGN-CS11S/Q) doesnt recognise the USB stick (Flash card). Device manager sees it but there are no drivers on the computer or online - search brings nothing. Never had such issue with any computer before. What do I do?
10 REPLIES 10
rich912
Hi Elina,
Unfortunately, due to current forum problems, I can’t see or access your latest post with attachment and can only respond to text contained in the email notification.
If the new flash drives are identical to the old ones that do work on your Vaio in both size and formatting then I’m afraid that I don’t have a clue as to what the problem is. Have you checked that they are all formatted the same – i.e. Fat32 or NTFS. Grasping at straws here but worth a look.
Rich
Go n-éirí an bóthar leat
