does anyone know where to download updated drivers for nvidia geforce go 7400 chip set for my vaio fe31h.
my operating system is xp
thanks. x
Hi Dai,
There do not appear to be any updated XP drivers available on the Sony download site.
The nVidia Forceware Vista Driver 97.46 is available HERE
What driver version are you using?
Im using 8.4.7.3 at the moment i think.
Trying to play Command and conquer 3 but i think my drivers are to old ..
How about any 3rd part driver updates .. any ides about them ??
Thnks x
Hi Dai,
Have a look here: -
http://www.laptopvideo2go.com/
They will have the very latest drivers - read the tutorial on 'modded .inf' files carefully!!
I would download MobileMeter and check your temperatures as your Vaio may overheat. If it does go back to the old drivers.
