Vaio F801A / WinXP / PCMCIA Card conflict
davcromp
I've upgraded my Vaio F801A to WinXP and now my Netgear 16 bit PCMCIA Card won't work. Do I need a 32 bit PCMCIA Card for my Vaio F801A running WinXP ?
rich912
Hi davcromp,
There is no native support for your 16 bit PCMCIA Card in XP but with the correct drivers from Netgear it should work. What is the Netgear model number?
Rich
Go n-éirí an bóthar leat
