Hi there, please can somebody tell me what VISTA to install on VAIO VGN-FE21H
Processor - x86 Family 6 Model 14 Stepping 8 GenuineIntel ~1662 Mhz
NVIDIA GeForce Go 7400
I've got an 64-bit upgrade but it doesn't start the installation...
thanx Elia
Your T2300 processor does not fully support 64-bit systems.
Core Duo only supports 32-bit - you need Core 2 Duo for 64-bit.
Sony only support the 32-bit system and there are only a few 64-bit programs to run. Although 64-bit is going to be a thing of the future, it is not practical for normal home usage yet - so you are not missing out.
Save yourself a lot of frustration and use the 32 bit edition, 64bit drivers are rarer then MS actually making a decent OS.
Na, 64bit drivers aren't rare. I would say it's nearly 47,5/52,5.
These 5% are mainly hardware like HiMD recorders and other exotic stuff.
Vista64 is far better supported than XP x64 ever.
Well, on OEM systems like Sony VAIO PCs, it's better to go for 32bit.
Because they won't support an OS which is different to the preinstalled one.
That isn't really a drawback, because you will get a PC which just works.
No trouble with bad drivers.
As Kee-Lo said, "Save yourself a lot of frustration"
thanks a lot for the answers - for a shame i made a mistake and bought 64 bit home premium - now I have Vista that i can't use...have to wait for the next computer to install it.
thanks again
Can you not take it back to the retailer and swap it. Tell them it was so confusing and the amount of Vista releases made you make a major error.
