Hi
I have a Vaio FE21M and, recentely, I bought a MS Wireless Notebook Optical Mouse 4000.
Since then, screensaver and power manager have stoped working... The screen is always on, even if I change the power options instead of screen saver.
If I remove the usb wireless connector everything works fine...
Any solution?
Thank you
Hi sendas,
welcome to Club vaio..
Did you install the MS drivers for your mouse..
Have you tried leaving the mouse on different surface as the mouse's optical reader may be detecting movement on the surface it's currently on..
