VAIO fit SVF15A13SGB
profile.country.IE.title
tuanct1997
How cana i active VTx in VAIO SVF15A13SGB ? I have aready accessed to BIOS setting but couldnt find where to enable VTx.
Im using ubuntu. Aready checked with kvm-ok in terminal and seem like i have VTx in my computer. Plz help me. Thanks
cass_n
Community Team
Hi @tuanct1997 and welcome to the community,
I'm not sure if this applies to your model, but might be worth a try:
  • When in BIOS hit the Right Arrow key only once.  (This will take you to the advanced tab)(
  • Hit the Enter key once.  (This will select the Top most option (virtualization)
  • Hit the Up Arrow key once. (This will move the selector from Disabled to Enabled)
  • Hit the Enter key once. (This will select Enabled)
  • Hit F10 to save and exit.
Cheers,
C
