Vaio flickering and jumping
@6756351301028857
My Vaio laptop jumps and flickers when you try to perform a taask ie clicking on a drop down mwnue or opening emails.  It is less than 1 year old.
What model Vaio do you have - it will start something like VPCxxxxxxx.
What Graphics driver version do you have installed? Does it look the same on an external monitor?
Does it only do it when you press a key or mouse button.  What happens if you move the Vaio gently?  It sounds like a bad connection to the screen.
Has it just started doing this?
:thinking:
