VAIO FS 315 B RECOVERY DISCS
fmo2000gr
Hello to everyone,
i have just bought the VAIO FS135B notebook.
When i first switched it on, i made the RECOVERY DISCS, it needed 2 DVDs. It completed successfully. Without any errors, i think. But i saw the in the Event Viewer, the System Log had 8 - 10 logs, indicating ERROR, and saying that some files or folders could not be read.
So maybe the RECOVERY DISCS will not work when i will need them.
WHAT CAN I DO???? Is there any way to test the Dics that are working properly???
PLEASEEEE HELP ME!!!!
If are not working what i can do to get right the RECOVERY DISCS????
Thank you very very much.
Moumtzis Fotis.
kee-lo_
You need a DVD checker program, the only one I know costs a bit, CD/DVD Diagnostic
