Have recently been unable to use the keyboard on my vaio as normal, something that my computer tells me is because I have turned on the shortcut key.
Can anyone tell me where this key is and how the heck I turn it off, it's driving me batty!
Edit:
Have somehow managed to fix the problem though sugestions are still welcome just incase it happens again!!
Hi soulreciever
Do you possibly mean sticky keys..?
You can turn StickyKeys on or off by pressing the SHIFT key five times...
Thanks for the advice! Fortunatly I solved the issue myself but I'll keep a note of this sollution just incase it happens again!!
Glad to see you've solved your keyboard problem soulreciever..
