HI, I have a vaio FX 604 and I'd like to Upgrade my 20GB Hard Disk. What kind of hard disk I can buy for the maximum upgrade? 30GB, 40GB, 60GB... What type of These 3 is possible? Thanks for all.................
GIGI
Think all you can do is 30GB
Make sure to get a 5400RPM or better
2.5inches which is I think 9cm.
No guarantees though
It's always possible to use a hard disk overlay program if willing to put in the extra work.
Hmmm yeah
This site seems to indicate that 80Gb isn't a problem with this model.
Remember there will be import tax on that in the UK
