Vaio laptop.
Ollieburd
Vaio laptop.
The little light, numbered 1, on the left, over the ASSIST button has disappeared from my computer?  How do I get it back and what does it do?
IamNic
Hello @Ollieburd,
if I am not mistaken (you gave very little info about which exact VAIO model you are using), it is the indicator LED, that the keypad is used in "number mode". You can activate it by pressing "Num Lk".
- Nic
IamNic
Hello @Ollieburd,
- Nic
Ollieburd
Thanks Nic. Simple thing - silly me! I never use the numbers and must have accidentally pressed the key.   Thanks again.
IamNic
Hello @Ollieburd,
@Ollieburd@  wrote:
Thanks again.
you are very welcome :slight_smile:
- Nic
