Vaio PCG-7R2L keyboard compability
butya4ok
Hello. My notebook is too old. It's Vaio PCG-7R2L. I need to replace keyboard module but can't find anywhere compatible models list. Can you help me?
Sean_Mc
Moderator
Hi there,
I'm looking into this and will update you when I have an answer.
In the meantime perhaps another member of the community might be able to offer help.
Best wishes,
Sean Mc
Sean_Mc
Moderator
Hi there,
I have sent you a PM to request more details.  If you could please reply to this Private Message in order for us to help you further.
Best wishes,
Sean Mc
PCG-7R2L is not a valid Vaio model. It is a code used internally by Sony for a group of Vaio models using a common chassis.
You may have more success finding a new keyboard if you use the correct model name to search. The correct model will be VGN-FExxxx. Try looking for this at the bottom right of the screen bezel.
Amazon and eBay seem to have several for sale and they seem to be compatible with all VGN-FE and VGN-AR model Vaios.
You will need to choose the colour and the language variant (US or UK, Black or White).
