Vaio PCV-F11M
scratchnow
Vaio PCV-F11M
Bought a second hand Vaio PCV-F11M All In One computer. Have inputed the model, Serial number into Sony support but cannot find any information.
I am desperate for a user or maintenence manual
Hi scratchnow and welcome.
The reason you cannot find any information is because you are using an invalid Vaio Model.  I think you are quoting the chassis type which is shared between several Vaio models.
Try to find another model code - it will be something like VGC-V2M - and it may be on the screen surround somewhere or in Control Panel -> Vaio Control Centre -> System Information.
If it is a VGC-V2M you can download the User Guide from the Support Pages here: -
http://www.sony.co.uk/support/en/product/vgc-v2m
:wink:
:wink:
scratchnow
Hi Blencogo, many thanks for that. You are correct it is VGC V2M. I took the other information from the rear of the PC. Thanks again
