Why won't update VAIO Peripherals Metadata 1.0.1.12090 install?
I have downloaded it manually & installed it or so I thought. Vaio update keeps listing it as an update.
Can anyone kindly assist?
Ta,
Oid
Solved! Go to Solution.
https://www.sony-europe.com/discussions/message/615317
You can find the answer here 😉
Cheers,
Nico
Cheers,
Nico
