Do any of you knows how to connect the Vaoi Pocket Player Cel.A (the one on offer) to the car stereo that has no tape player but only CD. Is there an accessory like the I-tune,.......hence shall I buy it or not? Pier
Sorry there is only one accessory for the VAIO Pocket at the moment which is the mysterious Slip Case which no one can find.
I guess an i tune type accesory could easily be made but it all depends on whether sony are still supporting the VAIO Pocket.
there are a number of FM radio transmitters available, most just have a lead which plugs into a 3.5mm jack socket, found on pretty much every prortable audio device including the vaio pocket. try ebay, they're not expensive, though they are illegal in the uk and perhaps elsewhere (technically they're pirate radio stations, but i don't think anyone's ever had a problem)
I may be off thread but you can get the Sony slip case here; http://www.microanvika.com/product.asp?TXT=INFO&PNO=SON19417 it's a good quality vinyl case with velcro flap and comes with the wrist strap all for £13.90 inc p&p. I can very highly recommend this company. In fact, it was this forum that pointed me in the direction of it!
it's fine for the 40gb, i ordered mine from there and have a 40gb. can't remember the part no. for my case but i doubt it's different from the one i have
this case is just fine for the 40gb model...
i posted something about this in the other thread conserning the case...please take a look there so i dont have to write everything again...:smileyhappy:
