VAIO Power Management doesn't load - Windows 7
SionJG
Hi
Just done a clean install from Vista Home Premium 32-bit to Windows 7 64-bit. I've installed all the VAIO drivers to recover hotkey functions etc, which all work fine. I can't get the Power Management to work however; it is installed according to Windows, but will not load from Control Center or appear as a tab in Windows Power Options.
Thanks!
0 REPLIES 0
