Vaio S Series 2.5" SSD caddy/SATA cable?
lbowers
I need to replace the Toshiba SSD drives that came with my Vaio SB laptops. Both machines current use mSATA (small connector and caddy) but I want to drop in two Intel SSD SATA drives. I need the full size SATA connector, and a caddy/caddy rails to fit the 2.5" drives.
Does anyone know which part numbers I need, or where to obtain the parts in the UK?
Many thanks
4 REPLIES 4
lbowers
Alternatively, do any other Vaios use the same caddy rails and connector, such as the SZ?
nimbystripes
I don't think so. Old and new Vaio models have different functionalities.
lbowers
Ah. Thanks for your help.
Do you know how I can find out which parts I need?
iamacle12
Bump! I would also like to know the answer to this.
