Ciao a tutti...
Troppo bello questo Vaio...ma qualcuno s adirmi come accedere alla lista dei Server con Vaio Setting Server?
Ho sbloccato il programma dal Firewall di Vista ma non riesco ugualmente.
grazie mille in anticipoo
You might not get a lot of help in here if you continue to post in italian...
Anyway, if you aren't thinking in using it you don't need to worry much. But if you are interested in using it, i don't see any problem if you choose only well-knowned servers and if you use software to protect your computer.
you're right!I'll try to do my best for my english!
many thanks for your post...i'll do as you said...
AVG and Checkpoint firewall is good for Vista.
hello kee-lo, many thanks for your prompt!
by...
Nessun problema, caio
