Vaio Smart Network Not Working Properly
RichVaio
Hi all,
Recently (within the last two weeks) the Vaio Smart Network will not load at start up and I am unable to load it by double clicking the .exe in program files. Has anyone else had this problem? If so, is there a solution to this problem?
Regards,
Rich
Hi Rich,
All I can suggest is that you reinstall the latest version of Vaio Smart Network.
What model Vaio do you have?
:thinking:
5 REPLIES 5
Hi Rich,
:thinking:
RichVaio
It seems to be an intermittent problem as rebooting the laptop sometimes works. The model I have is VPCEB4J0E. I think i will try and reinstall the VSN software and see if that works but where can i get the installation files from?
It is the bottom one on this downloads page of originally installed software for your model: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCEB4J0E_WI
Good Luck
:wink:
Nedster60
I recently uninstalled Vaio Smart Newtwork from my VPCEB4C5E - and good ridance!
After suffering from regular wireless failures it was a last resort that worked.
Windows 7 handles the wireless card fine, the only hassle is that you have to switch the Bluetooth adapter on and off using Device Manager, but for me that's not a problem.
Paul.A
I dont know if you are going to get this but my sony vaio e series is also not working properly becuse of the smart network my product no. is sve15115fxs
