Vaio SVS1511S9ES
davejo90
Vaio SVS1511S9ES
Can anyone tell me what the voltage is for a new memory module. I have a choice at Crucial but I cannot find the info anywhere either on my pc, bios or on the motherboard itself. .
Crucial does not recognise the PC either as it's so new and cannot detect the info of the spare slot.
I want to add 4GB of memory.
This is what is currently installed
Memory Size (GB)
4
Memory Type
PC3L-10600
Memory Specification
DDR3L SDRAM
Memory Speed (MHz)
1333
Thanks in advance
Dave
Hi Dave,
I have just re-read your post.  You need a 1.35 volt module.
The "L" in DDR3L SDRAM and PC3L-10600 stands for 'Low Voltage'.
DDR3/PC3 would be 1.5 volts.
DDR3L/PC3L is 1.35 volts.
DDR3U/PC3U is 1.25 volts.
:wink:
4 REPLIES 4
Hi davejo90 and welcome.
Does this thread help?
https://www.sony.co.uk/discussions/message/782247#782247
No easy answer I'm afraid.
Hi Dave,
:wink:
davejo90
That's brilliant Blencogo, thank you very much :slight_smile:
srmans2
I too am interested in upgrading the RAM on my laptop.
Out of interest where did you get the memory specification details in your original post?
On what has been said so far I'm thinking of getting this module:
http://www.crucial.com/uk/store/partspecs.aspx?IMODULE=CT51264BF1339
