Hi all,I try to install windows 7 rc in my pc (vgc-m1) and it work fine,also with xp driver!!!
The problem is an unexplainable high load cpu not displayed on the task manager,i tried all the solution are in my capacity but I don't resolve the problem.
The cpu works normal only in safe mode.
Any solutions for me????
Thanks at all,and sorry for my bad english!!!! :smileygrin: :smileygrin: :smileygrin:
Maybe i find the problem,disabling the processor driver.Now all work fine.
New problem for me
,the special key of my keyboard don't work.
Anyone have the solution for me???
You need to install the Vista Sony Utilities to get the special keys to work.
Go here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGC-M1&os=alt
and install in this order: -
1. Sony Utils DLL - 7.0.00.11210
2. Sony Shared Library - 3.0.00.10180
3. VAIO Event Service - 3.0.00.13110
You may find some other software you would like to install there also.
Don't work
:smileysad:. I installed in compatibilty mode.
These utilities are Vista utilities and should be compatible with Windows 7 without using any compatibility mode.
There are no Windows 7 Utilities so these are your best bet but they may not work with Win 7.
Partially resolved,I have installed the sony utils for XP,the brigthness function work properly but no the mute and sound function.
Why???
