Hi to you All
can some one help me please.
i have a vaio vgc-v3s i formatt the hard drive because of the proplem i Was having . because of the cd-dvd drive is not working, i have install the windows on it but i have a proplem with the screen which show small and i have proplem with audio , i try to get drivers from vaio but no luck, i have the recovery dvd but it doesnt work in external hard drive.
so
1.screen resulution
2. audio proplem
3. when i scrool makes fuzzy
thank you
Hi yolcu,
you can download the original drivers and utilities for you V3S via the Vaio support site..
To open Vaio support, either click Support at the top of this page or use the following link:Vaio support
Under Log-in option 2: Select your VAIO model, next to Select Model Category - Select your model from the drop down list, in your case VGC V.
Then next to Select Model - select VGC V3S
Then click Log-In
Once logged select Downloads the originally installed.
Hi First thank you For your time.
i try that , i download the driver its only let me instal wireles others doesnt have .exe its only some files for audios and for video car nvidia its runs but nothing happens, i try to download from nvidia but its doesnt recognise the any driver, i try to install recovery cd its not accept ing from external hard drive i try to change the boot from its runs the recovery but its blue screen comes after runs. my dvd drive on pc is goon doesnt read any cd.
i dont know how to fixed
kinde regard
Thank you
Hi yolcu,
for your graphics try the following..
Go to Start > Run type devmgmt.msc and press OK, Device Manager window should open, double click Display adaptors.
Right click once on the default graphics and select properties.
Select the 'Driver' tab and click on Update driver.
A new Hardware Update Window will appear, Select Don't search I will choose the driver to install and click Next,
Select Display adapters and click Next,
click Have Disk and browse to the downloaded original drivers folder called VideoNVidiaDriver,
select NVSZ.INF and click Open, Click OK
then click Next to install nVidia GeForce FX Go5700
Wait while the Wizard installs the new software
Click Finish when the installation complete screen appears
Restart the computer to finish
What is listed under other devices..
great!!! i done video bit by your help thanks
but i couldnt do the audio, if you can help please
thank you
For audio..
Open the downloaded original drivers folder and then open AudioAdi_AD1981B.
In the AudioAdi_AD1981B folder double click on Install.exe.
I did, but its load a second after its nothing happening.
