Vaio VGN-AR21S - XP Windows
graham-willcox
Uable to read blu-ray from disc
DVD/CD Rom Drive & RW works ok
Loaded all relavent Firmware with no luck
Never used blu-ray until last year - when noticed problem
Any ideas
Kind Regards
Graham
Thalamus.
Champion
Hi Graham,
do you still have the Sony supplied WinDVD BD installed on your Vaio.?
If so does it launch ok & what version is currently installed.?
To check the version number launch Win DVD BD then right click on the WinDVD BD for Vaio application window, from the list  select Set-Up.
In the new Set-Up window select the Information Tab.
