My apologies if this is already covered by a post here, but I couldn't find it if so (I realise it might also be in the manual, but that has long since disappeared).
Anyway, I'd like to know how to remove the keyboard on a Sony Vaio VGN-C1S. The space bar has become a little unresponsive in places and I think there might be something under the key. I've tried cleaning it as best as I can from above, but haven't improved things by much, so I wanted to just slip the keyboard out and try to give it a real good spraydust, vacuum and clean.
I'm guessing removal will be the usual remove a couple of screws then lift the keyboard out, but I don't want to start guessing at which screws!!
Any help much appreciated,
Cheers.
Mike
Hi Mike,
I have sent you a guide that should help with the keyboard removal via Private Message, use the following link to View your messages: Private Messages
Thank you very much - that screw was one of the ones I thought most likely, but I wouldn't have guessed it was only fixed by just one.
Cheers!!
Mike
