VAIO VGN-CS21S and windows 7
profile.country.pt_PT.title
ines14
Hi everyone, I would like to know if Vaio VGN- CS21S can have Windows 7 and works properly?
Thanks for helping me.
rich912
Hi ines14,
You should have no problem as all necessary Win 7 drives are available from Support.
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-CS21S_P&os=10
I’m unsure whether your OS version is 32-Bit or 64-Bit but if upgrading to Windows 7, as opposed to a clean install, you need to stay with the same version.
You may wish to run the Windows 7 Upgrade Advisor.
http://www.microsoft.com/download/en/details.aspx?id=20
Rich
Go n-éirí an bóthar leat
rich912
Hi ines14,
Rich
