VAIO VGN-FS415S ON TV??
madomng70
Hello, i'm from spain, and i wanna know if i can connect my vaio to tv with the cga conector. My tv has an rgb conector... is possible?
Unless your TV has a PC Socket - the same socket as your Vaio (VGA 15-Pin D-Sub) - then the picture will not synchronise.
You will need an expensive VGA to TV converter box LIKE THIS ONE or there are some USB to TV converters available for about €50.
:thinking:
