I've installed Windows Vista RC2 successfully on my Vaio VGN-S5/XP/B. Everything ist working fine, even WLAN and Bluetooth, so I'm basically happy (
) with it.
To get completely happy ( :smileygrin: ) you can maybe help me out.
Bluetooth is working but on the lowest (Microsoft) level. Means that I'm just be able to send one single file to a remote bluetooth device.
Device manager shows two items under bluetooth: "Microsoft Bluetooth Stack" and "Sony Bluetooth USB Device"
With original XP there was a bluetooth utility by sony to make it possible to send multiple files at once and some other goodies. I would like to check out, if that utility will work under Vista but I'm not able to find it on sony downloadsites or on the application recovery disk.
Has somebody an idea how to get that little bluetooth utility just to check it out under Vista or something similar to make it possible to send multiple files via bluetooth?
Thanx in advance.
CptGreenwood
