VAIO VGN-SZ1XP/c and docking station
bjornlieske
Hi! I have a problem. I bought a Docking Station VGP-PRSZ1 to My laptop VGN-SZ1xp/c. But when I try connect monitor by DVI, I have not a signal. What is happend? (But when I connect by D-SUB everthing is ok.)
robpaxton
You must make sure your computer is operating in speed mode before you can use the DVI-D connection. ie - using the nvidia graphics card.
bjornlieske
Everything is working, thank You so much!
