Vaio VPC S13 Keyboard removal
profile.country.fr_FR.title
daherau
Hi.
Following the breaking of a keyboard key, I must proceed to change my keyboard. I ordered one.
However, can not find how to remove the original keyboard on this model. Would you proceed?
The screw is there behind the HDD?
Thanks.
Ce message a été modifié par: daherau
rich912
For those seeking the same guidance daherau has kindly provided the position of the screws that hold the keyboard in place. Only the battery and HDD cover need to be removed to gain access to the screws.
Rich
Go n-éirí an bóthar leat
10 REPLIES 10
rich912
Hi daherau,
Try this link...
http://www.laptopkeyboard.com/Guides.php/Sony/VPC-S%20%28Black%29/VGP-S111FM/KBS37
Rich
daherau
Thank you for your answer
Unfortunately, how-to on this website are a bit generic and the same in all models. On VPCS13 if we removed all the screws hull does not come and I would not force it.
It would be logical that the screw is behind the keyboard unlocks the hard drive ? I've find a vidéo on youtube but for the YB séries. I've tried but it's not the same on my S13 :smileysad:.
rich912
Hi daherau,
Not having access to your particular model I can’t answer that question, but if there are screw holes on the replacement keyboard this should give you a good indication of where the corresponding screw should be.
Rich
daherau
I've tried to remove all screws back of my VAIO but no chance :smileysad:. Nothing come. This model is really complicated. There really is something mysterious to remove. The new keyboard does not help too much. There are screws everywhere:
You can see this keyboard here:
http://cgi.ebay.fr/Clavier-Azerty-Francais-VAIO-VPC-S-148779431-Backlit-/300429515297?pt=FR_JG_Infor...
I think I need to remove the rear before the fast keyboard screws ... But how to remove the shell?
I tried calling sony but unable to get an answer without send my computer to repair service and pay... A lot more than the keyboard price... 35 USD for the keyboard,  150 for repair...
rich912
The underside of the keyboard seems to show two screw holes that would be concealed by the top keyboard cover plus one in the middle of the keyboard. You may have already removed the middle screw but now need to release the keyboard cover to access the two screws from the top of the keyboard.
As stated previously I don’t have access to this model or disassembly instructions but if you send me an email address by PM (NOT on the open forum) I will send you instructions for another model that may hopefully point you in the right direction.
Rich
daherau
PM :wink:
rich912
PM replied to...
rich912
Rich
shalober
hi, i saw your message about keyboard. i am facing similar oroblem but you wre lucky bcz you found a keyboard but i m still looking for one. will you help in finding one or atleat direct me about the site or addess you found the keyboard, plz
