hello, i'd like to know if it's possible to upgrade my vaio with two 4gb pc3-10600 ram modules altough pc3-8500 as specified in the site.
thanx
Yes, you can use either PC3-8500 or PC3-10600.
Crucial.com guarantee both are compatible with your model and the price is the same for the 8GB kit.
http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VPCEC1S1E&Cat=RAM
