Hi there, BX396XP with 1.83 GHz core 2 duo and Radeon Mobility X1600 with 256mb hypermemory.
I was expecting a much better 2003 3DMark score than 1486. Can anyone think of any reasons why the score was so low? I was running on mains power and the cpu was set to 'adaptive' in the Vaio power management settings.
The Radeaon X1600 isn't a very powerful graphic chipset, and yours has hypermemory.
The true videoram is maybe 32MB or 64MB, and the rest is shared with systemram. That's a way to save costs and to increase battery lifetime
Anyway, this VAIO is made for business and not for gaming. You get smooth videoplayback. Not more not less.
Well, you could
a) upgrade the RAM
b) upgrade the hard disk
I'm not 100% sure this would take you over the 2000 mark, but it would possibly add a better score.
As Seb said the main issue here is that chipset for your graphics, it's shared, and it's integrated, and they're usually the main issue in slow graphics performance.
Well, you could
a) upgrade the RAM
I can understand your frustrations, the only thing I can think of is the bandwidth isn't as good, or the drivers are not as well put together.
It's always a good idea to read a few reviews and compare the 3DMark tests before buying, as graphics seem to be an important part of your computer use.
Turned all the Vaio power management crap off and ran the 2003 3D mark again....
New score = 5002
There, a perfectly acceptable score. I'm relieved now!
