VGA/HD15 to an S Video!!!!
g33
Hi guys i am desperately trying to get one of these in the UK
can anyone help!!!!!????
7 REPLIES 7
Eugenepang
hmm.. maybe you can buy it online and had it send to you?
g33
im not very good when it comes to ordering from places other than the UK, it sound pretty bad but im too impatient and it may not turn up!
kee-lo_
If they use someone like UPS you have no worries.
Jay1
check there customer feedback if they have one that might help you
robpaxton
There's the Avermedia AverKey Lite which does the same job from this UK site.....
g33
thanks Rob!!!! just what i been needing, do you think it will be OK on a widescreen display panel? shame the resolution doesnt go higher, but beggars cant be choosers!
robpaxton
Avermedia have a British website & contact address/telephone. The contact page is here
They should be able to give you more information.
