VGC-JS1E Sound Off
davsmith3551
VGC-JS1E Sound Off
My Pc says I have a Realtek HD Audio device.  I have installed the most recent driver and yet I am now informed that no Sound Device is installed.  Yet it appears on my Devive Manager list. ??
Help.
rich912
Hi Dave,
Your model is listed on the UK site.
http://www.sony.co.uk/support/en/product/VGC-JS1E_B/updates
I suggest that you try reinstalling the original driver.
Rich
Go n-éirí an bóthar leat
10 REPLIES 10
rich912
Hi davsmith3551,
As far as I can see there are no updated audio drivers available for your model on the Sony Support site so assume that you have installed a non Sony driver.
Drivers released by Sony are often taylored to the OEM device so original manufacturer drivers may not work as expected.
I suggest that you revert to the original driver either by download from Support or a driver rollback in Device Manager.
Rich
davsmith3551
No my Sony is original.  The model is VGC-JS1E.  Bought in Uk. I see it is not listed on their website.  I expect that is a USA site.
Can I risk updating/downloading a driver of one of the others model numbers that are close to my number on their list.??   Surely the model number should be shown on their UK list of models
Dave
rich912
Hi Dave,
Rich
davsmith3551
Hi Rich
I have found the driver in C:Windows/Drivers etc and got to Realtek Audio Driver  (File Folder)
When I click on this I get a long list with Folders
Config
DCC
Vista
Vista64
then a long list of other itemms
What do I click next
Setup   application ??
Lots of setup bits and pieces underneath it about setup etc
Dave
rich912
Hi Dave,
The driver that is available for download from the link I provided has a ‘Setup.exe’ within the root directory and therefore assume that you will find this in the Realtek driver folder on your hard drive – there is no need to open any folders within that directory.
Rich
davsmith3551
Thanks Rich
Do I just now click on Setup.exe and let it get on with it. I am afraid I am a bit of a beginner on folders/files etc.
Dave
rich912
Hi Dave,
Sorry I didn't make that clear - yes double click on Setup.exe.
If that doesn't solve the problem then there a couple more things we can try to get it to install.
Rich
davsmith3551
Cheers rich
Will do
and get back later.
Dave
davsmith3551
Hi Rich
FANTASTIC  :smileyhappy::smileyhappy::smileyhappy:
I have just played my wifes favourite love song LOUD  :laughing:
She thinks I am great at fixing things :wink:
Should be OK tonight !!  :heart_eyes:
Thanks a lot for your help.  Its a pity some web sites want to try and charge for simple solutions.
All the best
Dave
