Hello everyone,
I have a VGC LV1S that I have inherited. It has Windows 7 installed and seems to have only a few basic Sony applications installed.
I have two questions:
1) Sony Recovery Centre is not installed. There is a Recovery Partition on the hard drive but I don't know what is on it or if I should somwhow attempt to recover the system or not.
2) I am unable to adjust the screen brightness. The Sony Keyboard controls do not work and I would estimate the screen is set to full brightness - it is very bright. Does anyone know how I can reduce the screen brightness?
Any help greatly appreciated.
Stevie
Solved! Go to Solution.
Hi again Rich,
Great news! problem in Device Manager solved.
Can I ask one last question?
I didn't know there was a TV card on the VGC LV1S as I bought the PC from a friend.
Is there anyway of watching TV? Do I need specific Sony software?
Can I access the TV functions through Windows 7?
Stevie
Hi Stevie,
No sony software required just set it up in Windows Media Center - you will of course have to attach an aerial...
Rich
Hey Rich,
Just like to say a few words of thanks. My original problem plus two other niggles all resolved, professionally, swiftly and courteously.
Not sure if your are paid by Sony - but I'd like to register my sincere thanks.
Stevie
Message was edited by: stebird96
Hi Stevie,
Thanks for taking the trouble to say thanks - it is much appreciated:smileyhappy:.
No, I and other contributers to the forum are not paid by Sony, hence it is rewarding when someone expresses appreciation for the support we provide.
All the best,
Rich
Works like a charm. I had the same problem, but has already been fixed. Thanks. It saves me a lot of time figuring it out myself.
Hi Rich,
Thanks for the above advice.
My problem is similar to Stevie's. The problem being that I would like to replace the keyboard, but want to buy a cheap non-Vaio one. Is there any way to adjust the brightness without using the "Fn" key of the Vaio keyboard? Normal keyboards don't have that key, I think.
Also, the menu on the side of the screen of the VGC-LV1S does not seem to do much, as Stevie said. I followed your above steps, but nothing seems to have happened - the menu is still very basic and does not contain brightness controls.
Will
