- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
VGC-LV2SJ all in one PC
VGC-LV2SJ all in one desktop will not play pre-recorded Blu Ray Discs. Does anyone know if it should?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
According to the Specifications here - yes it should Read and Write BD Discs: -
http://support.vaio.sony.eu/computing/vaio/specifications/index.aspx?l=en_GB&m=VGC-LV2SJ
Have you installed all the Vaio Updates from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGC-LV2SJ
I see there is a WinDVD BD update there dated 5th April 2011?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The 5th April 2011 update was installed automatically although some of the earlier WinDVD BD updates failed to install. I don't know if this would affect this. In the autoplay section in the Control Panel there is no option listed for playing Blu Ray Discs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have finally got it to play Blu Ray Discs. When I purchased the PC it had Windows Vista installed. This was upgraded to Windows 7 with a disc supplied by Sony when it became available and it looks as if this upgrade did not install the player. I have just uninstalled Windows 7 and reinstalled Vista and the Corel WinDVD BD player has reappeared. Looks like I will have to stick with Vista now.
