For some reason my V2S now tells me when I select Live TV using VAIO Zone - "Tuner not connected". No signal seems to be present.
Also in the VAIO Zone Settings tool when I click TV it says "Cannot set some items because the TV Tuner settings are not complete. To complete all the settings, first perform the TV tuner settings and restart VAIO Zone." All the TV channels seem now to be blank.
Nothing has changed on my system since it was working earlier and the TV antenna cable is connected to the UHF input connector.
Any ideas ?
Many Thanks
George King
I would check device manager first and make sure that no devices are disabled and that they are all working correctly.
All devices appear to be fine.
George
I would re-install TV tuner card
I applied one of the VAIO utilities updates and it seemed to fix it.
GK
