vgc-v3s, line across the screen
vesbobic
i have sony vaio vgc-v3s model.
3cm wide vertical line appeared across the monitor running from top to bottom. the line is flashing, (flickering) with horizontal lines running across. what could be the problem and is it possible to deal with easily?
thank you
10 REPLIES 10
Thalamus.
Champion
Hi C46R11,
welcome to Questions & Answers..:smileyhappy:
Have you tried connecting your Vaio to an external monitor to see if you still have the same problem.?
If the lines do NOT appear on external monitor then cause is more likely the screen or screen connections..
This could prove costly so it unless you are in warranty I suggest you get a quote before committing to a repair..
You can either contact one of Sony's authorised repairers either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab to locate the nearest location.
Or
See if a local repairer in your area can give you an quote for repair, then depending on the cost decide whether you can live with purple line on  your screen..
