VGC - V3S unable to play DVD'd using Vaio Zone
grahamesson
My VGC V3S cannot play a DVD using Vaio Zone. I have to use WinDVD/RealPlayer or Windows Media player in order to play DVDs. Vaio zone has played DVD's in the past but not sure what has happened. I have re installed Vaio Zone and Vaio Entertainment using the recovery tool but to no avail.
Can anyone shed some light on what is wrong?
Many thanks
IanW06
Had this problem myself a while ago (just got rid of my v3s after 3 happy years). Don't if this is the problem but dvds will only play in Vaio Zone if the preinstalled version of Windvd (Windvd 5 for Vaio) is still your dvd decoder. Just reinstall it off the application recovery disc. Hope that helps if you haven't figured it out by now anyway. :slight_smile:
