Hello there!
I own a vgn-fe21s. In general i'm quite content with it, but i constantly lack a little bit of ram. Especially while running vista. Therefore I'd like to ask, whether it's possible to upgrade to 2 gb. Is there an available slot? If it would be possible, which type of Ram would be fitting?
Greetz
Hi illuminon,
According to the specs your vaio FE21S is upgradable to a maximum RAM of 2GB..
Crucial.com is a popular choice of memory supplier..
Here is a guide on how to replace or upgrade your Vaio's memory..
Hi Thalamus
Thanks for your quick reply! Now after you showed me i realise that i could have found that myself.. well.. 🙂
I've also another small matter which i would like to bring to discussion:
I read somewhere, that one of the notebooks weaknesses is the flaking of of the color on the system buttons (mute, soften, louder,..). I now have the same problem (till exactly today!). Has Sony a good solution for this problem? I daresay I'm not the first with this problem...
Greetz
