I installed the software updates as you said for my model, and the Hotfix for the Unknown Device of Device Manager, The S buttons worked ok But something odd is happening with the Brightness FN keys!!
When i press FN+F5 the brightness indication appears!! but.. 😞 it can change only between the first bar-spot and none. And as i do so, nothing changes to the brightness at all!
SEE WHAT I MEAN IN THE ATTACHES PHOTO!!!
I mean that i can not make the indication go up more than a single square when pressing FN+F6. Something ain't right / not compatible.
Please if you could tell me some idea!! I think that i 'll have to downgrade due to this!!
Grrrr!!!! 😞 ;( PLs help...
-->>VGN-FE31H VISTA WITH FN KEYS WORKING AT LAST!!!!
I made it!!!! I don't believe it!!
I found that the graphic's card driver was causing this issue!!
I installed the Driver giver in the Vaio Updates for vista for my model and that was it!
I did try several times to install that driver before, but i was getting an erron in installation. What was needed was to turn off the User Acount Control.
Ofcourse, hadn't it been for that Hotfix for the unknown device, i wouldn't have been able to fix it at all!!
I can now give directions to anyone else suffering rfom the same problem.
I'm happy now with my vista!!
