VGN FE31H Keyboard issue
profile.country.en_PK.title
xs2ahmed
Hi Guys,
I just happened to put some splashes of Coke on my keypad of VGN FE31h , i bought it like 3 months ago, 4 or 5 keys are now sticky, please help me what should i do. I am feeling really bad about it :slight_frown: ,.. please guide me,
Regards,
Ahmed
5 REPLIES 5
Thalamus.
Champion
Hi Ahmed,
Try a laptop keyboard cleaner and see if you can do to remove the stickiness.. :slight_frown:
xs2ahmed
what sort of cleaner ?
should i wet it ?
and does it require me to put out the keyboard?
Thalamus.
Champion
Hi xs2ahmed ,
If you go to a local PC shop they should be able to supply you with a laptop keyboard cleaner..
xs2ahmed
The cleaners i have come across can only clean surfance, either these are some liquids or sprays.
xs2ahmed
Is there a way to put out the whole keyboard panel or some keys?
actully only 5 keys are stciky, the rest of keyboard is perfect,
How about the service manual where can i get that ? which shows how to put this keyboard panel out.. or perhaps a few keys ?
