VGN FE31H
shak008
VGN FE31H
Hi does anyone know if it is possible to do a system recover and then not to install ALL the sony applications as created on the Applications recovery disk?
I dont want all the programs installed and just wondered if you could just install the system OS from the Reciovery disk 1, and then add just the basic stuff i need like mircorsoft office & itunes etc?
thanks
7 REPLIES 7
Thalamus.
Champion
Hi shak008
welcome to Club Vaio.. :slight_smile:
You may find the posts in this Formatting Without Installing Add On's thread of interest..
shak008
Many thanks Thalamus
I will let you know how i get on.
Thalamus.
Champion
You're welcome shak008, good luck..
shak008
I have a small problem now once I insert the applications disc it tries to install all the applications, I have stopped VARU.exe from the Starup within msconfig, but I just cant get the normal selection of Apps to install individually any ideas?
thanks
Shak
Hi Shak,
I don't think you can install individual Applications once you have cancelled the Applications Installation.
The only way to do this is by unpacking the Sony.PAC files on your Recovery Disc with kcap.exe.
Have a look at THIS THREAD
:wink:
shak008
Many thanks Blencogo, will give it a try.
Thalamus.
Champion
Did you manage to install the applications you required Shak..?
