VGN-FW11E bios update how long to instal
amcbiker
I am in the process of a bios update using the windows installer and it has now been running for 2 hours. There is occasional hard drive activity.
Please does anyone know how long this normally takes ?
I don't want to stop the instal in case it all goes wrong.
Any advice would be most appreciated.
Dave
14 REPLIES 14
amcbiker
Hi Rich,
I was just looking for a download of Arcsoft Webcam companion as at the moment not installed.
Do you reckon it should work with instant Messenger ?
Dave
rich912
Hi Dave,
Yes it should work with Instant Messenger. Make sure that the correct camera is selected as default – Tools > Audio and Video Setup...
Rich
Go n-éirí an bóthar leat
rich912
Hi Dave,
Sorry, I assume you are referring to Windows Live Messenger?
Rich
amcbiker
Hi Rich,
yes that works fine now.
Thanks for all your help.
Dave
rich912
You’re welcome Dave:smileyhappy:
